Salta al contenuto principale
Frigidaire FFHB2750TD6 Water Filter Replacement
  1. Frigidaire FFHB2750TD6 Water Filter  Replacement, Water Filter: passo 1, immagine 1 di 2 Frigidaire FFHB2750TD6 Water Filter  Replacement, Water Filter: passo 1, immagine 2 di 2
    • On the right inner side of the fridge, you will find the model number.
    • Identifying the correct model number will ensure the proper purchase of the new water filter.
  2. Frigidaire FFHB2750TD6 Water Filter  Replacement: passo 2, immagine 1 di 3 Frigidaire FFHB2750TD6 Water Filter  Replacement: passo 2, immagine 2 di 3 Frigidaire FFHB2750TD6 Water Filter  Replacement: passo 2, immagine 3 di 3
    • Click options on the control panel on the front of the left door.
    • Here it will say ice maker is on, click the minus button to turn it off.
    • You will hear a beeping sound to ensure that the ice maker is turned off.
  3. Frigidaire FFHB2750TD6 Water Filter  Replacement: passo 3, immagine 1 di 1
    • The water filter is in the upper right corner of the fridge.
  4. Frigidaire FFHB2750TD6 Water Filter  Replacement: passo 4, immagine 1 di 3 Frigidaire FFHB2750TD6 Water Filter  Replacement: passo 4, immagine 2 di 3 Frigidaire FFHB2750TD6 Water Filter  Replacement: passo 4, immagine 3 di 3
    • To remove the water filter turn it to the right until you feel it detach.
    • Then pull the filter straight out slowly from its slot.
    • Water may drip from the filter upon removal. Putting a towel underneath and removing products from that area will ensure an easy clean-up.
  5. Frigidaire FFHB2750TD6 Water Filter  Replacement: passo 5, immagine 1 di 2 Frigidaire FFHB2750TD6 Water Filter  Replacement: passo 5, immagine 2 di 2
    • Once the filter is removed, identify the model number on it.
    • The model number will ensure you buy the correct replacement at the store.
  6. Frigidaire FFHB2750TD6 Water Filter  Replacement: passo 6, immagine 1 di 2 Frigidaire FFHB2750TD6 Water Filter  Replacement: passo 6, immagine 2 di 2
    • Upon getting the new filter from the store install it into the fridge.
    • Insert the filter straight into its designated slot.
    • Twist the filter to the right until you feel and hear it click into place.
  7. Frigidaire FFHB2750TD6 Water Filter  Replacement: passo 7, immagine 1 di 2 Frigidaire FFHB2750TD6 Water Filter  Replacement: passo 7, immagine 2 di 2
    • To turn the icemaker back on click the options button and hit the minus button, it will beep indicating it is back on.
    • To reset the water filter you hit the down arrow button beneath the options button and go down to "water filter".
    • Press and hold the set button above the minus button on the right side, it will then say "good" next to the water filter.
    • Press options again to return to the main screen.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 72
Tutti i Tempi: 4,157
