Salta al contenuto principale
Frigidaire FCRE3052A Oven Light Replacement
Cosa ti serve
  1. Frigidaire FCRE3052A Oven Light Replacement, Oven Light: passo 1, immagine 1 di 3 Frigidaire FCRE3052A Oven Light Replacement, Oven Light: passo 1, immagine 2 di 3 Frigidaire FCRE3052A Oven Light Replacement, Oven Light: passo 1, immagine 3 di 3
    • Unplug the oven carefully.
    • Open the oven and locate the light on the upper left side at the back of the oven.
  2. Frigidaire FCRE3052A Oven Light Replacement: passo 2, immagine 1 di 3 Frigidaire FCRE3052A Oven Light Replacement: passo 2, immagine 2 di 3 Frigidaire FCRE3052A Oven Light Replacement: passo 2, immagine 3 di 3
    • Slide the securing wire over the glass cover.
    • Remove the glass cover and set it aside.
  3. Frigidaire FCRE3052A Oven Light Replacement: passo 3, immagine 1 di 3 Frigidaire FCRE3052A Oven Light Replacement: passo 3, immagine 2 di 3 Frigidaire FCRE3052A Oven Light Replacement: passo 3, immagine 3 di 3
    • Gently twist the old light bulb to the left to unscrew it, then remove it from the oven.
    • Replace it with the new bulb, twisting it to the right until it is securely in place.
  4. Frigidaire FCRE3052A Oven Light Replacement: passo 4, immagine 1 di 3 Frigidaire FCRE3052A Oven Light Replacement: passo 4, immagine 2 di 3 Frigidaire FCRE3052A Oven Light Replacement: passo 4, immagine 3 di 3
    • Before replacing the glass cover, consider cleaning it if it has significant grease or grime buildup.
    • Replace the glass cover back over the light bulb.
    • Slide the securing wire across the top of the glass cover to hold it in place.
    • Ensure that the glass cover and wire are securely in place.
  5. Frigidaire FCRE3052A Oven Light Replacement: passo 5, immagine 1 di 3 Frigidaire FCRE3052A Oven Light Replacement: passo 5, immagine 2 di 3 Frigidaire FCRE3052A Oven Light Replacement: passo 5, immagine 3 di 3
    • Plug the oven back into the outlet carefully.
    • If the cord is located behind the oven it is helpful to push the cord against the back wall before sliding the oven back into place.
  6. Frigidaire FCRE3052A Oven Light Replacement: passo 6, immagine 1 di 2 Frigidaire FCRE3052A Oven Light Replacement: passo 6, immagine 2 di 2
    • Open the oven door to confirm that the new light is working properly.
Conclusione
Laura Tapia
Membro da: 09/09/24
133 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 51
Tutti i Tempi: 158
