Salta al contenuto principale
Introduzione
If the lawn chair on your wheelchair is broken, learn how to replace it!
But first, familiarize yourself with tools you will be using with the Free Wheelchair Mission Tools Maintenance Guide.
Strumenti
Ricambi
Nessuna parte specificata.
  1. Locate the four straps on each corner of the cushion. Untie each of the straps and remove the cushion from the chair.
    • Locate the four straps on each corner of the cushion.
    • Untie each of the straps and remove the cushion from the chair.
  2. Turn the chair around and locate the two base plates that hold the axle to the back of the chair. There are two screws on each of the plates that connect the chair to the axle. Hold the nut with the pliers. In the other hand, use the 10mm wrench to remove the screw.
    • Turn the chair around and locate the two base plates that hold the axle to the back of the chair.
    • There are two screws on each of the plates that connect the chair to the axle.
    • Hold the nut with the pliers. In the other hand, use the 10mm wrench to remove the screw.
  3. Remove both of the screws from each of the axle plates to free the chair from the axle.
    • Remove both of the screws from each of the axle plates to free the chair from the axle.
    • Make sure too keep track of which bolts belong to certain parts of the wheelchair. You do not want to loose track of where each bolt belongs.
  4. Locate both of the brakes. They are each located on the front of the chair between the rear tire and the frame.
    • Locate both of the brakes. They are each located on the front of the chair between the rear tire and the frame.
    • There are two screws connecting each of the brakes to the frame.
    • Remove both of the screws from the frame using the 10mm wrench and pair of pliers.
  5. Remove the brakes from the frame. Repeat with the brake on the other side of the wheelchair.
    • Remove the brakes from the frame.
    • Repeat with the brake on the other side of the wheelchair.
  6. Locate the screws that hold the back frame, chair, castor wheel, and front frame together. There is one screw on each side of the chair immediately above where the brakes are located.
    • Locate the screws that hold the back frame, chair, castor wheel, and front frame together.
    • There is one screw on each side of the chair immediately above where the brakes are located.
    • Remove both of these screws using the 10mm wrench and a pair of pliers.
  7. Remove the front frame and each of the castor wheels from the wheelchair.
    • Remove the front frame and each of the castor wheels from the wheelchair.
  8. Remove the lawn chair from the back frame by lifting it up.
    • Remove the lawn chair from the back frame by lifting it up.
Conclusione
To place a new lawn chair into the wheelchair, follow these instructions in reverse order.
Altre 3 persone hanno completato questa guida.
David Schaeffer
Membro da: 19/04/2013
118 Reputazione
1 Guida realizzata
Cal Poly, Team 14-7, Maness Spring 2013 Membro di Cal Poly, Team 14-7, Maness Spring 2013
CPSU-MANESS-S13S14G7
5 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 865
