Salta al contenuto principale
Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement
  1. Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement, Engine Air Filter: passo 1, immagine 1 di 1
    • Pull out the hood release in the driver's footwell to pop open the hood.
  2. Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement: passo 2, immagine 1 di 2 Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement: passo 2, immagine 2 di 2
    • Release the hood latch to lift the hood.
    • To avoid difficulty finding the latch, search near the center of the hood.
  3. Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement: passo 3, immagine 1 di 2 Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement: passo 3, immagine 2 di 2
    • Position hood prop rod into the support hole.
    • Hoods are heavy and the securement of the prop rod is necessary to prevent injury.
  4. Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement: passo 4, immagine 1 di 1
    • Unlatch the three clips securing the engine air filter cover. (The third clip can't be seen in the photo but is on the other side of the cover.)
    • Be sure to allow the vehicle to cool down before working in the engine bay.
  5. Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement: passo 5, immagine 1 di 1
    • Gently remove the air filter cover.
  6. Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement: passo 6, immagine 1 di 1
    • Remove the filter by simply pulling it out of the filter compartment.
Conclusione
Ahmad Elahi
Membro da: 01/21/21
169 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 45
Tutti i Tempi: 804
