Salta al contenuto principale
Fossil Speedway Watch TI-5061 Watchband Link Replacement
Cosa ti serve
  1. Fossil Speedway Watch TI-5061 Watchband Link Replacement, Band Link: passo 1, immagine 1 di 1
    • Locate the link on the band with arrows pointing in opposite directions.
    • Place push pin into the hole on one side of the link.
  2. Fossil Speedway Watch TI-5061 Watchband Link Replacement: passo 2, immagine 1 di 1
    • Hit the push pin with the blunt object (we used scissors) until the small metal rod sticks out from the link.
    • Pull the rod out using your fingers.
    • Repeat on the other side to remove the entire link.
  3. Fossil Speedway Watch TI-5061 Watchband Link Replacement: passo 3, immagine 1 di 2 Fossil Speedway Watch TI-5061 Watchband Link Replacement: passo 3, immagine 2 di 2
    • To replace the link, insert the open end of one of the connected links into the open end of the new link.
    • Place the rod into the aligning holes and use the blunt object to hammer the rod into the link.
    • Repeat on the other side of the link to remove it completely.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 14-10, Amido Spring 2015 Membro di Cal Poly, Team 14-10, Amido Spring 2015
CPSU-AMIDO-S15S14G10
3 Membri
5 Guide realizzate
1Commento della guida
Looking for 3 extra watch band links for a fossil big tic model jr8622 18mm width could you tell me please how much this will cost please with delivery as well to croydon in Surrey
Kind regards colin
Colin Evans - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,647
