Salta al contenuto principale
Fossil Speedway Watch TI-5061 Replacement of the Back
Cosa ti serve
  1. Fossil Speedway Watch TI-5061 Replacement of the Back, Clasp: passo 1, immagine 1 di 3 Fossil Speedway Watch TI-5061 Replacement of the Back, Clasp: passo 1, immagine 2 di 3 Fossil Speedway Watch TI-5061 Replacement of the Back, Clasp: passo 1, immagine 3 di 3
    • Keep clasp in open position.
    • Push one of the spring-loaded pins out of the hole with a Push-pin.
    • Wiggle watch band and clasp till free from each other.
  2. Fossil Speedway Watch TI-5061 Replacement of the Back, Back: passo 2, immagine 1 di 1
    • Fit the blades of a pair of scissors into the grooves of the screw back.
    • Twist the screw back counter clockwise with the scissors.
    • Once the back is loose enough, you can use your fingers to twist it off.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 14-10, Amido Spring 2015 Membro di Cal Poly, Team 14-10, Amido Spring 2015
CPSU-AMIDO-S15S14G10
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,132
