Salta al contenuto principale
Fossil Q Marshal Gen 2 Screen Replacement
Cosa ti serve
  1. Fossil Q Marshal Gen 2 Screen Replacement, Back Cover: passo 1, immagine 1 di 1
    • Squeeze retaining pins together to release chain from watch body. This can be done by hand or with tweezers.
    • Remove chain from opposing side of watch body.
  2. Fossil Q Marshal Gen 2 Screen Replacement: passo 2, immagine 1 di 1
    • Use tweezers to grip the notches on the back cover, then unscrew the back cover (counter-clockwise) from the watch housing.
    • There is an actual tool made to remove this back cover, using the right tool may save you from scratching the back of watch with tweezers. The backcover tool can be purchased online, a local jeweler may also be willing to remove it for you.
  3. Fossil Q Marshal Gen 2 Screen Replacement: passo 3, immagine 1 di 2 Fossil Q Marshal Gen 2 Screen Replacement: passo 3, immagine 2 di 2
    • Utilize tweezers or a spudger or your fingers to pull the black wire connector from the motherboard.
    • Utilize a spudger to pull the orange connector off of the motherboard.
  4. Fossil Q Marshal Gen 2 Screen Replacement: passo 4, immagine 1 di 1
    • Utilize tweezers to pull the white battery connector from the motherboard.
  5. Fossil Q Marshal Gen 2 Screen Replacement: passo 5, immagine 1 di 3 Fossil Q Marshal Gen 2 Screen Replacement: passo 5, immagine 2 di 3 Fossil Q Marshal Gen 2 Screen Replacement: passo 5, immagine 3 di 3
    • The internal electronics can now be pulled out of the watch as one unit leaving the screen remaining in the watch housing.
    • Taking the flat end of the spudger, pry it up.
  6. Fossil Q Marshal Gen 2 Screen Replacement, Screen: passo 6, immagine 1 di 2 Fossil Q Marshal Gen 2 Screen Replacement, Screen: passo 6, immagine 2 di 2
    • The screen can now be removed out of the front-side of the watch.
    Where can I buy the replacement screen from?
    Lazarus Dsilva - Replica
    Where can I find you so that my screen can be replaced? I am in Nairobi Kenya
    Peterson mbogo - Replica
    Boas tardes. Onde poderei encontrar um ecrã. Parti o meu e não encontro em lado nenhum será possível ajudar obrigado
    Adriano melim - Replica
Conclusione
Altre 12 persone hanno completato questa guida.
IUPUI, Team S2-G5, Harley Fall 2017 Membro di IUPUI, Team S2-G5, Harley Fall 2017
IUPUI-HARLEY-F17S2G5
3 Membri
6 Guide realizzate
17 Commenti
Where can i find a replacement screen for the founder q 2.0 version?
Jack Seitz - Replica
Where can I buy replacement screen for gen 1
David Aslamazashvili -
Is the screen glued to the bezel of the watch?
Jose - Replica
Hello,
Do you have spare parts for the Fossil Q Marshal gen 2 watch?
Alexis Stellato - Replica
Where can I find a replacement screen for this devise?, I’ve done a little searching but I’m struggling to find someone who sells the replacement parts.
evans.nathan6 - Replica
Where can I get a replacement for this screen?
Has podido encontrar el repuesto?
Pablo Fernando Rios Corredor -
Hola, donde consigo el repuesto de la pantalla? Gracias
Pablo Fernando Rios Corredor - Replica
Guys, Scroll down to “store” then choose your country then do your search.
Queenbee - Replica
Need replacement glass is cracked where can I find one
julyknight81 - Replica
I need his lcd plz help me where can i buy
Mehran Cheema - Replica
Anyone find replacement screens?
Mark Coyle - Replica
I need the screen
benziggy93 - Replica
Where can I get a screen replacement, battery and Home button of Fossil Q MARSHALL watch
philbert alfred - Replica
the screen of smart watch is only half the pictures are visible the other side is blackout but it is touchable
where can i buy or find screen for the smart watch fossil
Jennifer Larracas - Replica
I’ve searched every single shop all around the world, but didn’t found any Fossil Smartwatch Display. Where can I get it from? I need on efor my Fossil Q Explorist HR (Gen 4) and I suggest it’s the same Display as the one for the Q Marshall.
Kai Loh - Replica
ડીસપ્લેબદવીછે
rajan khatri - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 50
Tutti i Tempi: 18,901
