Salta al contenuto principale
Fossil Q Marshal Gen 2 Screen Replacement
Cosa ti serve
  1. Fossil Q Marshal Gen 2 Screen Replacement, Back Cover: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Squeeze retaining pins together to release chain from watch body. This can be done by hand or with tweezers.
    • Remove chain from opposing side of watch body.
  2. Fossil Q Marshal Gen 2 Screen Replacement: passo 2, immagine 1 di 1
    • Use tweezers to grip the notches on the back cover, then unscrew the back cover (counter-clockwise) from the watch housing.
    • There is an actual tool made to remove this back cover, using the right tool may save you from scratching the back of watch with tweezers. The backcover tool can be purchased online, a local jeweler may also be willing to remove it for you.
  3. Fossil Q Marshal Gen 2 Screen Replacement: passo 3, immagine 1 di 2 Fossil Q Marshal Gen 2 Screen Replacement: passo 3, immagine 2 di 2
    • Utilize tweezers or a spudger or your fingers to pull the black wire connector from the motherboard.
    • Utilize a spudger to pull the orange connector off of the motherboard.
  4. Fossil Q Marshal Gen 2 Screen Replacement: passo 4, immagine 1 di 1
    • Utilize tweezers to pull the white battery connector from the motherboard.
  5. Fossil Q Marshal Gen 2 Screen Replacement: passo 5, immagine 1 di 3 Fossil Q Marshal Gen 2 Screen Replacement: passo 5, immagine 2 di 3 Fossil Q Marshal Gen 2 Screen Replacement: passo 5, immagine 3 di 3
    • The internal electronics can now be pulled out of the watch as one unit leaving the screen remaining in the watch housing.
    • Taking the flat end of the spudger, pry it up.
  6. Fossil Q Marshal Gen 2 Screen Replacement, Screen: passo 6, immagine 1 di 2 Fossil Q Marshal Gen 2 Screen Replacement, Screen: passo 6, immagine 2 di 2
    • The screen can now be removed out of the front-side of the watch.
Conclusione
Altre 12 persone hanno completato questa guida.
IUPUI, Team S2-G5, Harley Fall 2017 Membro di IUPUI, Team S2-G5, Harley Fall 2017
IUPUI-HARLEY-F17S2G5
3 Membri
6 Guide realizzate
17 Commenti
Where can i find a replacement screen for the founder q 2.0 version?
Jack Seitz - Replica
Where can I buy replacement screen for gen 1
David Aslamazashvili -
Is the screen glued to the bezel of the watch?
Jose - Replica
Hello,
Do you have spare parts for the Fossil Q Marshal gen 2 watch?
Alexis Stellato - Replica
Where can I find a replacement screen for this devise?, I’ve done a little searching but I’m struggling to find someone who sells the replacement parts.
evans.nathan6 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 37
Tutti i Tempi: 19,043
