Salta al contenuto principale
Fossil Q Marshal Gen 2 Disassembly
Cosa ti serve
  1. Fossil Q Marshal Gen 2 Disassembly, Back Cover: passo 1, immagine 1 di 1
    • Squeeze retaining pins together to release chain from watch body. This can be done by hand or with tweezers.
    • Remove chain from opposing side of watch body.
  2. Fossil Q Marshal Gen 2 Disassembly: passo 2, immagine 1 di 1
    • Use tweezers to grip the notches on the back cover, then unscrew the back cover (counter-clockwise) from the watch housing.
    • There is an actual tool made to remove this back cover, using the right tool may save you from scratching the back of watch with tweezers. The backcover tool can be purchased online, a local jeweler may also be willing to remove it for you.
  3. Fossil Q Marshal Gen 2 Disassembly: passo 3, immagine 1 di 2 Fossil Q Marshal Gen 2 Disassembly: passo 3, immagine 2 di 2
    • Utilize tweezers or a spudger or your fingers to pull the black wire connector from the motherboard.
    • Utilize a spudger to pull the orange connector off of the motherboard.
  4. Fossil Q Marshal Gen 2 Disassembly: passo 4, immagine 1 di 1
    • Utilize tweezers to pull the white battery connector from the motherboard.
  5. Fossil Q Marshal Gen 2 Disassembly: passo 5, immagine 1 di 3 Fossil Q Marshal Gen 2 Disassembly: passo 5, immagine 2 di 3 Fossil Q Marshal Gen 2 Disassembly: passo 5, immagine 3 di 3
    • The internal electronics can now be pulled out of the watch as one unit leaving the screen remaining in the watch housing.
    • Taking the flat end of the spudger, pry it up.
Conclusione
Altre 5 persone hanno completato questa guida.
IUPUI, Team S2-G5, Harley Fall 2017 Membro di IUPUI, Team S2-G5, Harley Fall 2017
IUPUI-HARLEY-F17S2G5
3 Membri
6 Guide realizzate
4 Commenti
How do you remove the power switch?
Rahim Parpia - Replica
So when i go to reverse the process. It feels like I connect the top screen and top pieces back in and it won't turn on. Any reason why. Sometimes it vibrates them dnt come up.
Justin Huron - Replica
Thanks, i droped my Fossil Q Founder 2.0 (FTW2119) and this guide help me fix it, i recomend put in the name that also works with mine.
Abílio Páscoa - Replica
Which battery do I need for this watch. I need a replacement.
Pamela Asamoah - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 46
Tutti i Tempi: 12,755
