Salta al contenuto principale
Fosera Scandle 200 Solar Panel Replacement
Cosa ti serve
  1. Fosera Scandle 200 Solar Panel Replacement, Solar Panel: passo 1, immagine 1 di 1
    • Open the case by pulling the back tab toward you in a downward motion.
  2. Fosera Scandle 200 Solar Panel Replacement: passo 2, immagine 1 di 1
    • Unscrew the two Phillips #2 5mm screws that hold the power cord in place.
  3. Fosera Scandle 200 Solar Panel Replacement: passo 3, immagine 1 di 1
    • Use the flat-end of the spudger to pry off the clamp which holds the cord down.
  4. Fosera Scandle 200 Solar Panel Replacement: passo 4, immagine 1 di 1
    • Use the soldering iron to melt down the solder on each terminal by holding the tip of the iron against the solder until it becomes liquefied.
  5. Fosera Scandle 200 Solar Panel Replacement: passo 5, immagine 1 di 1
    • Gently pull the leads free from the terminals. If they do not easily separate from the terminals, repeat Step 4.
    • Now any solar panel of appropriate Voltage rating can be used to charge the device by soldering the wire leads to the new panel. Try to find a panel with similar specifications to avoid overloading the battery.
Conclusione
Vincent C
Membro da: 09/23/14
134 Reputazione
1 Guida realizzata
USF Tampa, Team 12-5, Blackwell Fall 2014 Membro di USF Tampa, Team 12-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G5
4 Membri
11 Guide realizzate
3Commenti sulla guida
In order to use solar energy efficiently, we need to learn how to store solar energy. Unfortunately, we can only store a small fraction of the sun's energy.
niks adonis - Replica Condividi
More information here.
niks adonis - Condividi
Go to the link.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 28
Tutti i Tempi: 847
