Salta al contenuto principale
Fosera Scandle 200 Motherboard Removal
Cosa ti serve
  1. Fosera Scandle 200 Motherboard Removal, Motherboard Removal: passo 1, immagine 1 di 1
    • To open up the casing, you will need to unscrew the four Phillips #0 15mm screws which are accessible from the back.
  2. Fosera Scandle 200 Motherboard Removal: passo 2, immagine 1 di 1
    • Gently separate the two halves of the casing.
  3. Fosera Scandle 200 Motherboard Removal: passo 3, immagine 1 di 1
    • Disconnect the battery from the motherboard by lifting up on the white plastic tab on the top of the connection.
    • Gently pull the cord out by the white plastic adapter. Do not pull from the red and black cord.
  4. Fosera Scandle 200 Motherboard Removal: passo 4, immagine 1 di 1
    • Unscrew the Phillips four #0 15mm screws to free the motherboard from the casing.
  5. Fosera Scandle 200 Motherboard Removal: passo 5, immagine 1 di 1
    • Slowly pull the motherboard out of the casing. Make sure the loose battery wire doesn't get snagged.
Linea Traguardo
USF Tampa, Team 12-5, Blackwell Fall 2014 Membro di USF Tampa, Team 12-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G5
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 301
