Introduzione
After too many charging cycles, the battery's capacity will be decreased. This is true for any Lithium-ion battery. Luckily the replacement of the battery in this device is very simple.
Cosa ti serve
To open up the casing, you will need to unscrew the four Phillips #0 15mm screws which are accessible from the back.
Remove the four #0 15mm screws to release the battery housing from the case.
