Salta al contenuto principale
Forerunner 620 Battery and/or Screen Replacement
Cosa ti serve
  1. Forerunner 620 Battery and/or Screen Replacement, Remove LCD: passo 1, immagine 1 di 2 Forerunner 620 Battery and/or Screen Replacement, Remove LCD: passo 1, immagine 2 di 2
    • Carefully remove the display of the watch by thoroughly heating the display and gently prying with the help of a suction cup.
  2. Forerunner 620 Battery and/or Screen Replacement, Remove the main board: passo 2, immagine 1 di 1
    • Remove the screws which secure the main board in place.
  3. Forerunner 620 Battery and/or Screen Replacement, Replace battery: passo 3, immagine 1 di 3 Forerunner 620 Battery and/or Screen Replacement, Replace battery: passo 3, immagine 2 di 3 Forerunner 620 Battery and/or Screen Replacement, Replace battery: passo 3, immagine 3 di 3
    • If the connector for the battery breaks, you can solder the connections directly to the motherboard.
    • If the connector is still intact, you can simply clip the new one into place.
  4. Forerunner 620 Battery and/or Screen Replacement, Replace the LCD: passo 4, immagine 1 di 1
    • If the LCD is broken, you can replace it by removing the two flat cables which connect it to the main board.
    • The touch screen cable has a lock with a small white lever which should be lifted gently to remove the cable.
  5. Forerunner 620 Battery and/or Screen Replacement, Glue and put it back: passo 5, immagine 1 di 3 Forerunner 620 Battery and/or Screen Replacement, Glue and put it back: passo 5, immagine 2 di 3 Forerunner 620 Battery and/or Screen Replacement, Glue and put it back: passo 5, immagine 3 di 3
    • You can now glue the display back in place using B-7000 adhesive.
Conclusione
phico
Membro da: 03/22/21
295 Reputazione
2 Guide realizzate
10Commenti sulla guida
Where did you find the replacement battery?
Clarence Chung - Replica
I bought this model on Amazon : "
CELLONIC® Smartwatch Replacement Battery PD3032, 361-00047-0 Compatible with Garmin Approach S1, Forerunner 110, Forerunner 210, Forerunner 610, Forerunner S1 Replacement Battery 200 mAh Battery Fitness Tracker
Philippe Collignon -
Do you have the dimensions of the original battery?
Is B7000 adhesive necessary?... or will E6000 also work the same?
Thanks in advance.
jjc - Replica
Changed the battery, all good, except that the touch screen is no longer responding to my touch. :<
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 42
Tutti i Tempi: 3,715
