Salta al contenuto principale
Ford Focus Door Interior dome light assembly Replacement
Cosa ti serve
  1. Ford Focus Door Interior dome light assembly Replacement, interior dome light: passo 1, immagine 1 di 2 Ford Focus Door Interior dome light assembly Replacement, interior dome light: passo 1, immagine 2 di 2
    • Remove the screw cover in the handle housing using a flathead screwdriver.
  2. Ford Focus Door Interior dome light assembly Replacement: passo 2, immagine 1 di 2 Ford Focus Door Interior dome light assembly Replacement: passo 2, immagine 2 di 2
    • Remove the screw that is holding the handle housing with a T20 Torx screwdriver.
  3. Ford Focus Door Interior dome light assembly Replacement: passo 3, immagine 1 di 2 Ford Focus Door Interior dome light assembly Replacement: passo 3, immagine 2 di 2
    • Carefully pull the handle housing off.
    • Do not pull too hard. There are wires attached to the back of the housing.
  4. Ford Focus Door Interior dome light assembly Replacement: passo 4, immagine 1 di 3 Ford Focus Door Interior dome light assembly Replacement: passo 4, immagine 2 di 3 Ford Focus Door Interior dome light assembly Replacement: passo 4, immagine 3 di 3
    • Detach the wires on the handle housing with a flathead screwdriver by pushing upwards on the release slot.
  5. Ford Focus Door Interior dome light assembly Replacement: passo 5, immagine 1 di 2 Ford Focus Door Interior dome light assembly Replacement: passo 5, immagine 2 di 2
    • Remove the cover on the door grip by prying gently with a flathead screwdriver.
  6. Ford Focus Door Interior dome light assembly Replacement: passo 6, immagine 1 di 2 Ford Focus Door Interior dome light assembly Replacement: passo 6, immagine 2 di 2
    • Take off the inside door panel by removing all screws with a T20 Torx screwdriver.
    • There are nine screws in total: two on the front, three on the outer side, two on bottom, and two on the inner side.
  7. Ford Focus Door Interior dome light assembly Replacement: passo 7, immagine 1 di 3 Ford Focus Door Interior dome light assembly Replacement: passo 7, immagine 2 di 3 Ford Focus Door Interior dome light assembly Replacement: passo 7, immagine 3 di 3
    • Pull the insulation back to access the door handle bracket.
    • Use an X-acto knife if needed.
  8. Ford Focus Door Interior dome light assembly Replacement: passo 8, immagine 1 di 3 Ford Focus Door Interior dome light assembly Replacement: passo 8, immagine 2 di 3 Ford Focus Door Interior dome light assembly Replacement: passo 8, immagine 3 di 3
    • Remove the two screws holding the handle bracket with a T20 Torx screwdriver.
  9. Ford Focus Door Interior dome light assembly Replacement: passo 9, immagine 1 di 3 Ford Focus Door Interior dome light assembly Replacement: passo 9, immagine 2 di 3 Ford Focus Door Interior dome light assembly Replacement: passo 9, immagine 3 di 3
    • Remove the outside door handle by prying gently with a flathead screwdriver to loosen, and then slide it back.
  10. Ford Focus Door Interior dome light assembly Replacement: passo 10, immagine 1 di 3 Ford Focus Door Interior dome light assembly Replacement: passo 10, immagine 2 di 3 Ford Focus Door Interior dome light assembly Replacement: passo 10, immagine 3 di 3
    • Detach the door latch rod from the handle bracket by pulling the plastic end out of the metal loop.
  11. Ford Focus Door Interior dome light assembly Replacement: passo 11, immagine 1 di 2 Ford Focus Door Interior dome light assembly Replacement: passo 11, immagine 2 di 2
    • Pull the locking rod free from the handle bracket and remove the broken handle bracket.
Conclusione
Altre 5 persone hanno completato questa guida.
Cassidy
Membro da: 03/21/16
241 Reputazione
1 Guida realizzata
Un commento
Excellent guide. I should have watched the video before disassembly. Actually got part from coastal ford for $40. Same as napa but actual Ford part! And in stock. Thanks Glen
glenthomas784 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 47
Tutti i Tempi: 23,215
