To fully restart the power management unit be sure to remove the AC adapter and the battery first and let the PowerBook sit without power for several minutes.
  • To fully restart the power management unit be sure to remove the AC adapter and the battery first and let the PowerBook sit without power for several minutes.
  • Go to back of computer.
Aggiungi Commento
Have a pen or small enough object and push it into small hole closest to power button
  • Have a pen or small enough object and push it into small hole closest to power button
  • You should hear the startup chime
Aggiungi Commento
  • If the computer still exhibits the same issue, repeat steps 1 and 2 and then follow the step listed below before reinstalling the battery.
  • Using two paper clips, simultaneously press and hold down the reset and interrupt buttons for 5 to 10 seconds.
Aggiungi Commento
Conclusione
David Kehley
Membro da: 11/04/2013
101 Reputazione
1 Guida realizzata
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 377
