Salta al contenuto principale
FoodSaver V4980 Liquid Chamber Accessory Replacement
  1. FoodSaver V4980 Liquid Chamber Accessory Replacement, Liquid Chamber Accessory: passo 1, immagine 1 di 1
    • The liquid chamber accessory can be found on the top-left side of the appliance.
  2. FoodSaver V4980 Liquid Chamber Accessory Replacement: passo 2, immagine 1 di 1
    • Pull the black top (identified with the rubber loop) from the liquid chamber. You may now replace/clean the accessory.
Conclusione
Cal Poly, Team 34-17, Maness Spring 2016 Membro di Cal Poly, Team 34-17, Maness Spring 2016
CPSU-MANESS-S16S34G17
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 27
Tutti i Tempi: 2,072
