Salta al contenuto principale
FoodSaver V4980 Bag Cutter Arm Replacement
  1. FoodSaver V4980 Bag Cutter Arm Replacement, Bag Cutter Arm: passo 1, immagine 1 di 1
    • Open the device cover as shown in the image.
  2. FoodSaver V4980 Bag Cutter Arm Replacement: passo 2, immagine 1 di 2 FoodSaver V4980 Bag Cutter Arm Replacement: passo 2, immagine 2 di 2
    • Pull on the left side of the handle to release the bar from the holder.
    • Not much force is required for the cutter arm to come loose. If it seems stuck squeeze the main arm sides together, as shown in the second photo
Conclusione
Cal Poly, Team 34-17, Maness Spring 2016 Membro di Cal Poly, Team 34-17, Maness Spring 2016
CPSU-MANESS-S16S34G17
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 265
