Salta al contenuto principale
FlySky FS-TH9X Joystick Spring Replacement
Cosa ti serve
  1. FlySky FS-TH9X Joystick Spring Replacement, FlySky FS-TH9X Disassembly: passo 1, immagine 1 di 1
    • On the back of the remote, you will see 6 5mm Phillips #2 head screws.
    • The six screws on the front of the remote are screws that disconnect the joysticks from the remote and cannot be used to remove the back panel.
  2. FlySky FS-TH9X Joystick Spring Replacement: passo 2, immagine 1 di 1
    • Using a size two Phillips screwdriver, remove the six 5 mm Phillips #2 head screws
  3. FlySky FS-TH9X Joystick Spring Replacement: passo 3, immagine 1 di 1
    • Using a pry tool with a little pressure, carefully pull apart the remote to expose the inside.
  4. FlySky FS-TH9X Joystick Spring Replacement: passo 4, immagine 1 di 1
    • Continue to troubleshooting your device.
  5. FlySky FS-TH9X Joystick Spring Replacement, FlySky FS-TH9X Joystick Spring: passo 5, immagine 1 di 1
    • Remove screws to open the device and reveal the inside. For this section we will be working with the top half of the remote.
  6. FlySky FS-TH9X Joystick Spring Replacement: passo 6, immagine 1 di 1
    • Locate this section of your device underneath the joysticks.
  7. FlySky FS-TH9X Joystick Spring Replacement: passo 7, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Using a pair of thin tweezers or pliers, remove the spring from its holding hook on the arm first and then from the holding hook on the other end of the spring.
  8. FlySky FS-TH9X Joystick Spring Replacement: passo 8, immagine 1 di 1
    • Remove the plastic "arm" piece that the spring is connected to and replace the spring or "arm" piece as necessary.
    • It is easier to start attaching the spring to the holding hook attached to the actual remote, then attach the spring the "arm" piece.
  9. FlySky FS-TH9X Joystick Spring Replacement: passo 9, immagine 1 di 1
    • 1. Replace the spring starting from the bottom holding hook.
    • 2. Slide the plastic "arm" piece back into place.
    • 3. Attach the spring to the arm piece.
    • Once completed it will look like the image shown here. Re-assemble the controller and test the joysticks to make sure everything is working properly again.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 49
Tutti i Tempi: 427
