Salta al contenuto principale
FlySky FS-TH9X Joystick Replacement
Cosa ti serve
  1. FlySky FS-TH9X Joystick Replacement, FlySky FS-TH9X Disassembly: passo 1, immagine 1 di 1
    • On the back of the remote, you will see 6 5mm Phillips #2 head screws.
    • The six screws on the front of the remote are screws that disconnect the joysticks from the remote and cannot be used to remove the back panel.
  2. FlySky FS-TH9X Joystick Replacement: passo 2, immagine 1 di 1
    • Using a size two Phillips screwdriver, remove the six 5 mm Phillips #2 head screws
  3. FlySky FS-TH9X Joystick Replacement: passo 3, immagine 1 di 1
    • Using a pry tool with a little pressure, carefully pull apart the remote to expose the inside.
  4. FlySky FS-TH9X Joystick Replacement: passo 4, immagine 1 di 1
    • Continue to troubleshooting your device.
  5. FlySky FS-TH9X Joystick Replacement, FlySky FS-TH9X Joystick: passo 5, immagine 1 di 1
  6. FlySky FS-TH9X Joystick Replacement: passo 6, immagine 1 di 1
    • Carefully remove chassis from outer casing.
  7. FlySky FS-TH9X Joystick Replacement: passo 7, immagine 1 di 1
    • Gently remove wiring from circuit.
    • To replace this part please contact the manufacturer, or consult the internet, to purchase parts.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 104
