Introduzione
Over continued use, the joystick tends to move on it's own without you moving the joystick. This is fixable by replacing the entire joystick. This guide consist of the steps required to open the remote, dislocate the joysticks and than replacing said joysticks.
Cosa ti serve
On the back of the remote, you will see 6 5mm Phillips #2 head screws.
Locate and unscrew the 6 2.5mm Phillips #1 screws, holding the joystick mechanism it its chassis.
