Salta al contenuto principale
FlySky FS-TH9X Antenna Wire Disconnected
Cosa ti serve
  1. FlySky FS-TH9X Antenna Wire Disconnected, FlySky FS-TH9X Antenna Wire Disconnected: passo 1, immagine 1 di 1
    • On the back of the remote, locate the antenna box labeled in red.
  2. FlySky FS-TH9X Antenna Wire Disconnected: passo 2, immagine 1 di 1
    • Unplug the wire that connects the antenna box to the controller.
  3. FlySky FS-TH9X Antenna Wire Disconnected: passo 3, immagine 1 di 1
    • On either side of the box, squeeze the clips and pull up to release the antenna box away from its socket.
  4. FlySky FS-TH9X Antenna Wire Disconnected: passo 4, immagine 1 di 1
    • Unscrew the two 2.5 mm Phillips #1 screws with a screwdriver and carefully remove the front plate.
  5. FlySky FS-TH9X Antenna Wire Disconnected: passo 5, immagine 1 di 1
    • Once you remove it, you will see a wire that is connected to the antenna, and a motherboard.
  6. FlySky FS-TH9X Antenna Wire Disconnected: passo 6, immagine 1 di 1
    • Locate the brass colored socket and the end of the wire and carefully connect them together.
    • It should click together.
  7. FlySky FS-TH9X Antenna Wire Disconnected: passo 7, immagine 1 di 1
    • Once connected assemble the box back together.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 143
