Salta al contenuto principale
Fluance RT83 Belt Replacement
Cosa ti serve
  1. Fluance RT83 Belt Replacement, Belt: passo 1, immagine 1 di 1
    • Unplug the turntable.
  2. Fluance RT83 Belt Replacement: passo 2, immagine 1 di 1
    • Lock the tonearm in place with the tonearm clip.
    • If the tonearm is not locked in place, it could move around and potentially damage the needle
  3. Fluance RT83 Belt Replacement: passo 3, immagine 1 di 1
    • Lift the rubber mat and place it to the side.
    • The rubber mat should come off easily, as it is simply resting on top of the metal platter.
  4. Fluance RT83 Belt Replacement: passo 4, immagine 1 di 1
    • Unhook the drive belt from the motor pulley.
    • The drive belt is carefully wrapped around the motor pulley, so it is important to unhook it gently.
  5. Fluance RT83 Belt Replacement: passo 5, immagine 1 di 1
    • Remove the drive belt from the metal platter.
  6. Fluance RT83 Belt Replacement: passo 6, immagine 1 di 1
    • Grab the new drive belt.
    • Wrap the new drive belt around the motor pulley.
    • Note: When reassembling the turntable, don't forget to wrap the new drive belt around the motor pulley.
  7. Fluance RT83 Belt Replacement: passo 7, immagine 1 di 1
    • Once your drive belt is hooked around the motor pulley, continue wrapping the drive belt around the entire metal platter.
    • If you are having difficulty wrapping the new drive belt around the metal platter, go very slowly and gently. Patience may be required for this step.
  8. Fluance RT83 Belt Replacement: passo 8, immagine 1 di 1
    • Make sure your drive belt is flush against the platter.
    • It is very important there are no twists in your drive belt.
  9. Fluance RT83 Belt Replacement: passo 9, immagine 1 di 1
    • Give your metal platter a gentle spin clockwise.
    • When spinning, the platter should continue to spin for a few seconds on its own.
    • If your metal platter is able to spin with the new drive belt attached, you have successfully installed your drive belt.
  10. Fluance RT83 Belt Replacement: passo 10, immagine 1 di 1
    • Place the rubber mat back on top of the metal tray platter.
Conclusione
Test by playing a record.
Austin Daniel
Membro da: 09/20/23
181 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 32
Tutti i Tempi: 261
