Salta al contenuto principale
Flipper Zero Display Replacement
Cosa ti serve
    • Go to Main Menu > Settings > Power.
    • Select Power OFF, and confirm by pressing the Right-button.
  1. Flipper Zero Display Replacement, Remove the microSD card: passo 2, immagine 1 di 1
    • Eject the microSD card by pressing it with your fingernail.
    • Use a PH1 screwdriver to unscrew the four long screws holding the back cover.
    • Be careful, the screws are quite easy to strip.
  2. Flipper Zero Display Replacement, Open the back cover: passo 4, immagine 1 di 3 Flipper Zero Display Replacement, Open the back cover: passo 4, immagine 2 di 3 Flipper Zero Display Replacement, Open the back cover: passo 4, immagine 3 di 3
    • Press the middle of the top cover on both sides, one by one, to release the latches that hold the back cover in place.
    • Once the latches are released, you can remove the bottom cover.
    • Use a PH0 screwdriver to unscrew the two short screws that are holding the chassis and top cover together.
    • Once the screws are removed, separate the chassis from the top cover.
    • Disconnect the battery by carefully prying the connector with a Spudger and pulling it out.
    • Disconnect the large ribbon cable from the board. Use a plastic pick to lift the latch up to open the lock and carefully pull it out of the connector.
  3. Flipper Zero Display Replacement, Release the battery chassis: passo 8, immagine 1 di 2 Flipper Zero Display Replacement, Release the battery chassis: passo 8, immagine 2 di 2
    • To release the battery chassis, lightly rock it back and forth while pulling the two parts apart.
    • Be sure to apply gentle and consistent pressure to avoid damaging the device.
    • Unscrew the two short screws holding the button chassis using a PH0 screwdriver.
  4. Flipper Zero Display Replacement, Seperate the button chassis: passo 10, immagine 1 di 3 Flipper Zero Display Replacement, Seperate the button chassis: passo 10, immagine 2 di 3 Flipper Zero Display Replacement, Seperate the button chassis: passo 10, immagine 3 di 3
    • To seperate the button chassis and the board, press the latch on the side shown below and pull the chassis away from the board.
    • Disconnect the screen ribbon cable from the board. Use a plastic pick to lift the latch up to open the lock and carefully pull it out of the connector.
  5. Flipper Zero Display Replacement, Desolder the screen: passo 12, immagine 1 di 1
    • To remove the screen you need to desolder two contacts.
    • See this guide on how to solder and desolder connections.
Conclusione
Altre 2 persone hanno completato questa guida.
Sebastian Dorr
Membro da: 08/19/18
8.250 Reputazione
44 Guide realizzate
2 Commenti
Where do we get the screen?
Malav Vyas - Replica
Currently you can't, unless you take them from another broken flipper. They are custom made and have a different pinout from normal displays, but Flipper devices have stated that they will start selling replacement parts soon™.
Sebastian Dorr -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 20
Ultimi 7 Giorni: 141
Ultimi 30 Giorni: 710
Tutti i Tempi: 1,970
