Salta al contenuto principale
Flip Video Ultra Power button Replacement
Cosa ti serve
  1. Flip Video Ultra Power button Replacement, Power button: passo 1, immagine 1 di 1
    • Unlock the battery cover by sliding the switch to the unlock position.
  2. Flip Video Ultra Power button Replacement: passo 2, immagine 1 di 1
    • Remove the battery cover by sliding it down the camera.
  3. Flip Video Ultra Power button Replacement: passo 3, immagine 1 di 1
    • Remove the batteries
  4. Flip Video Ultra Power button Replacement: passo 4, immagine 1 di 1
    • Slide the black upper casing off from the device.
  5. Flip Video Ultra Power button Replacement: passo 5, immagine 1 di 2 Flip Video Ultra Power button Replacement: passo 5, immagine 2 di 2
    • Remove the six 1mm screws from the back and upper casing with the Phillips Head screwdriver.
  6. Flip Video Ultra Power button Replacement: passo 6, immagine 1 di 1
    • Remove the top casing from the bottom to reveal the inner circuit board.
  7. Flip Video Ultra Power button Replacement: passo 7, immagine 1 di 2 Flip Video Ultra Power button Replacement: passo 7, immagine 2 di 2
    • When removing the back panel, the rubber buttons will become loose and likely fall off the board. This is normal and can easily placed back on the board once finished.
    • Remove the six 1mm screws with the 1 Phillips head screwdriver.
  8. Flip Video Ultra Power button Replacement: passo 8, immagine 1 di 1
    • Gently separate the circuit board from the casing.
  9. Flip Video Ultra Power button Replacement: passo 9, immagine 1 di 2 Flip Video Ultra Power button Replacement: passo 9, immagine 2 di 2
    • Unscrew the single 1mm screw from USB housing unit.
  10. Flip Video Ultra Power button Replacement: passo 10, immagine 1 di 2 Flip Video Ultra Power button Replacement: passo 10, immagine 2 di 2
    • Unscrew the 2 1mm screws and gently separate camera wires from plastic casing.
  11. Flip Video Ultra Power button Replacement: passo 11, immagine 1 di 1
    • Gently pry out the USB housing unit with the Ifxit Opening Tool.
  12. Flip Video Ultra Power button Replacement: passo 12, immagine 1 di 3 Flip Video Ultra Power button Replacement: passo 12, immagine 2 di 3 Flip Video Ultra Power button Replacement: passo 12, immagine 3 di 3
    • Remove the two 1mm screws and separate the circuit board and camera from the plastic casing.
  13. Flip Video Ultra Power button Replacement: passo 13, immagine 1 di 1
    • Unscrew the camera housing unit from the plastic case.
Conclusione
Nathaniel Ruf
Membro da: 10/18/16
514 Reputazione
5 Guide realizzate
UMass Dartmouth, Team 5-7, Martin Fall 2016 Membro di UMass Dartmouth, Team 5-7, Martin Fall 2016
UMASSD-MARTIN-F16S5G7
3 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 623
