Salta al contenuto principale
Flip MinoHD USB Port Replacement
Cosa ti serve
  1. Flip MinoHD USB Port Replacement, Battery: passo 1, immagine 1 di 2 Flip MinoHD USB Port Replacement, Battery: passo 1, immagine 2 di 2
    • With the Phillips screwdriver 000, unscrew the two small screws securing the battery to the outer case and set safely aside.
    • With the plastic opening tool, pry the battery out of device and set aside. Now the battery is fully removed.
  2. Flip MinoHD USB Port Replacement, USB Port: passo 2, immagine 1 di 3 Flip MinoHD USB Port Replacement, USB Port: passo 2, immagine 2 di 3 Flip MinoHD USB Port Replacement, USB Port: passo 2, immagine 3 di 3
    • Using Phillips screwdriver 000, unscrew the 4 screws from the outer casing. Now the small white microphone should disconnect and is free to be set aside.
    • With Phillips screwdriver 000, unscrew the 3 screws which secure the aluminum USB bracket.
    • Using tweezers, remove the USB port from the device. Your device is now a skeleton and is ready for replacement. To do so, follow these steps backwards.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 460
