Salta al contenuto principale
Flip MinoHD Casing Replacement
Cosa ti serve
  1. Flip MinoHD Casing Replacement, Casing: passo 1, immagine 1 di 2 Flip MinoHD Casing Replacement, Casing: passo 1, immagine 2 di 2
    • With the plastic opening tool, remove labels from the Flip Mino HD. 2 small black screws should appear.
    • With the Phillips Screwdriver 000, unscrew the 2 screws and set aside in a safe place.
  2. Flip MinoHD Casing Replacement: passo 2, immagine 1 di 2 Flip MinoHD Casing Replacement: passo 2, immagine 2 di 2
    • With the plastic opening tool, gently pry the front casing away from the device by carefully running the tool around each edge and lifting.
    • Do not pull to remove the casing until all sides are loose. You may break or crack the case.
    • Once case is loose, flip up and over the device. Note that casing is still connected to the device.
    • Using tweezers, pull connecting strip to disconnect it from its socket on the logic board.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 580
