Salta al contenuto principale
Flexible vacuum hose detaches from wand ...too easily
Cosa ti serve
  1. Flexible vacuum hose detaches from wand ...too easily, Detach flexible hose from wand: passo 1, immagine 1 di 1
    • Likely it will already be detached since the detent clip springs are so weak
  2. Flexible vacuum hose detaches from wand ...too easily, Remove screw that holds detent clip holder: passo 2, immagine 1 di 1
    • #2 Phillips screw driver
  3. Flexible vacuum hose detaches from wand ...too easily, Replace the two springs: passo 3, immagine 1 di 1
    • By compressing the springs you can remove the clip and spring. Replace these weak springs with stronger springs that are commonly carried at hardware stores for faucet repair
  4. Flexible vacuum hose detaches from wand ...too easily, Reassemble in reverse order.: passo 4, immagine 1 di 1
    • Insert wisdom here.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 246
