Salta al contenuto principale
Fleetwood Monarch 62" Recurve Bow String Replacement
Cosa ti serve
  1. Fleetwood Monarch 62" Recurve Bow String Replacement, String: passo 1, immagine 1 di 1
    • Remove the broken or damaged bow string.
  2. Fleetwood Monarch 62" Recurve Bow String Replacement: passo 2, immagine 1 di 1
    • One end of the new bowstring will have a loop with a larger diameter than the other. Take the larger loop and secure it onto one end of the bow.
  3. Fleetwood Monarch 62" Recurve Bow String Replacement: passo 3, immagine 1 di 1
    • Slide the larger loop halfway down the limb of the bow.
  4. Fleetwood Monarch 62" Recurve Bow String Replacement: passo 4, immagine 1 di 1
    • Secure the smaller loop onto the other end of the bow.
  5. Fleetwood Monarch 62" Recurve Bow String Replacement: passo 5, immagine 1 di 3 Fleetwood Monarch 62" Recurve Bow String Replacement: passo 5, immagine 2 di 3 Fleetwood Monarch 62" Recurve Bow String Replacement: passo 5, immagine 3 di 3
    • Place your left leg between the bow shaft and the bow string.
    • Place your foot behind the end of the bow touching the ground.
    • Place one hand near the middle of the bow and the other hand on the string, close to the larger loop.
    • Push down on the top end of the bow and slide the larger loop into place.
Conclusione
Enjoy your new bow-string!
Zachery Kail
Membro da: 09/16/20
121 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 21
Tutti i Tempi: 952
