Salta al contenuto principale
Flash and re-install the firmware of TCA Yoke
Cosa ti serve
    • Download and install the driver package from here.
    • TCA Yoke and TCA Quadrant both use the same driver.
    • Press on the Windows button and type "Firmware Update" into the search.
    • Unplug your TCA Yoke from USB port if you already have it plugged-in
  1. Flash and re-install the firmware of TCA Yoke, Press and hold the XBOX button: passo 4, immagine 1 di 1
    • Press and hold the Xbox button.
    • Make sure to set your Yoke into PC mode, using the switch at the back, before proceeding to the next step.
  2. Flash and re-install the firmware of TCA Yoke, Connect to USB while holding the Xbox button: passo 5, immagine 1 di 1
    • Keep holding the Xbox button and connect the Yoke to USB port.
    • Once connected, wait a few seconds and let go of the button.
    • Your TCA Yoke should show up in Firmware Updater.
    • Press OK on the Firmware Updater and wait for update to complete.
Linea Traguardo
Formica Fusca
Membro da: 08/01/24
2.595 Reputazione
15 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 33
Tutti i Tempi: 307
