Salta al contenuto principale
Flash and re-install the firmware of TCA Quadrant
    • Download and install the driver package from here.
    • TCA Yoke and TCA Quadrant both use the same driver.
    • Press on the Windows button and type "Firmware Update" into the search.
    • Unplug your TCA Quadrant from USB port if you already have it plugged-in.
  1. Flash and re-install the firmware of TCA Quadrant, Press and hold the indicated button: passo 4, immagine 1 di 1
    • Press and hold the button highlighted on the picture.
  2. Flash and re-install the firmware of TCA Quadrant, Connect to PC while holding the button: passo 5, immagine 1 di 1
    • Keep holding the button and connect the Quadrant to USB port of your PC.
    • Once connected, wait a few seconds and let go of the button.
    • You must connect directly to USB port of your PC. It will not work if you connect it to USB port of your Yoke.
    • Your TCA Quadrant should show up in Firmware Updater.
    • Press OK on the Firmware Updater and wait for update to complete.
Linea Traguardo
Formica Fusca
Membro da: 08/01/24
2.595 Reputazione
15 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 194
