Introduzione
If your flash settings are set correctly but your camera does not flash, you will need to replace the flash motherboard. First, you will need to remove the front and back covers. Once that is complete, you will have access to the flash motherboard.
Strumenti
Parti
Nessuna parte specificata.
Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
There are 2 screws on the left side (when looking at the front of the camera).
There are 3 screws on the bottom
There is 1 screw on the right side
Turn to the front of the camera.
Find the flash motherboard located behind the flash assembly on the top right.
Altre 2 persone hanno completato questa guida.
