Salta al contenuto principale
Flash Motherboard
Cosa ti serve
    1. Flash Motherboard, Front and Back Covers: passo 1, immagine 1 di 3 Flash Motherboard, Front and Back Covers: passo 1, immagine 2 di 3 Flash Motherboard, Front and Back Covers: passo 1, immagine 3 di 3
      • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
      • There are 2 screws on the left side (when looking at the front of the camera).
      • There are 3 screws on the bottom
      • There is 1 screw on the right side
      Chiedi a FixBot
      Aggiungi Commento
    2. Flash Motherboard: passo 2, immagine 1 di 1
      • Turn to the bottom of the camera.
      • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
      Chiedi a FixBot
      Aggiungi Commento
    3. Flash Motherboard: passo 3, immagine 1 di 1
      • This is what the SD card/battery compartment looks like when opened.
      • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    4. Flash Motherboard: passo 4, immagine 1 di 2 Flash Motherboard: passo 4, immagine 2 di 2
      • Gently remove the front cover away from the camera body.
      • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
      Chiedi a FixBot
      Aggiungi Commento
    5. Flash Motherboard: passo 5, immagine 1 di 1
      • The camera should look like this once the front cover is removed.
      Chiedi a FixBot
      Aggiungi Commento
    6. Flash Motherboard: passo 6, immagine 1 di 3 Flash Motherboard: passo 6, immagine 2 di 3 Flash Motherboard: passo 6, immagine 3 di 3
      Strumento utilizzato in questo passaggio:
      • Start from the battery compartment and remove the back cover.
      • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
      • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
      Chiedi a FixBot
      Aggiungi Commento
    7. Flash Motherboard: passo 7, immagine 1 di 1
      • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
      Chiedi a FixBot
      Aggiungi Commento
    1. Flash Motherboard, Flash Motherboard: passo 8, immagine 1 di 1
      • Turn to the front of the camera.
      • Find the flash motherboard located behind the flash assembly on the top right.
      Chiedi a FixBot
      Aggiungi Commento
    2. Flash Motherboard: passo 9, immagine 1 di 1
      • Use a soldering iron and a desoldering wick to disconnect the wires from the marked locations.
      • Once the cables are disconnected, you are now ready to install a new motherboard.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Jakub
Membro da: 04/19/11
134 Reputazione
2 guide realizzate
Cal Poly, Team 8-6, Regan Spring 2011 Membro di Cal Poly, Team 8-6, Regan Spring 2011
CPSU-REGAN-S11S8G6
4 Membri
22 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 26
Tutti i Tempi: 4,497
