Salta al contenuto principale
Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler
Cosa ti serve
  1. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler, Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 1, immagine 1 di 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler, Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 1, immagine 2 di 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler, Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 1, immagine 3 di 3
    • Turn your label-maker on its face. Using your thumb, press in and then upward on the fastener located on the side of your device.
  2. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 2, immagine 1 di 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 2, immagine 2 di 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 2, immagine 3 di 3
    • Remove the batteries from your device.
  3. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 3, immagine 1 di 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 3, immagine 2 di 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 3, immagine 3 di 3
    • Using a plastic opening tool from your iFixit tool kit, leverage the label cartridge out of your device.
  4. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 4, immagine 1 di 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 4, immagine 2 di 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 4, immagine 3 di 3
    • Press the label paper back into alignment with the small holders on the right side of the label cartridge.
  5. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 5, immagine 1 di 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 5, immagine 2 di 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 5, immagine 3 di 3
    • Place the label cartridge and batteries back into your device. Refasten the bottom case of the label-maker.
  6. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 6, immagine 1 di 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 6, immagine 2 di 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: passo 6, immagine 3 di 3
    • Well done! You have successfully corrected the paper-jam in your Brother PT-90 Label-Maker.
Conclusione
Kaitlyn Abrams
Membro da: 10/13/16
1 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 793
