Salta al contenuto principale
Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm
Cosa ti serve
  1. Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm, Opening the Device: passo 1, immagine 1 di 1
    • Flip device upside down and remove the 4 foam pads at each corner.
    • Remove the 4 screws using a Philips Screwdriver.
    • Gently lift the case off of the body and set down in a safe place.
  2. Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm, Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm: passo 4, immagine 1 di 1
    • Unscrew the 5 screws in the base circuit board.
  3. Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Use the tweezers to slightly lift the circuit board, allowing the cylindrical alarm piece to slide out.
  4. Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm: passo 6, immagine 1 di 1
    • Check if the wires are secured.
    • If they are not attached, you may re-solder it together. If they are attached, that means it is a faulty alarm and should replace it.
Conclusione
Altre 3 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 31
Tutti i Tempi: 1,896
