Salta al contenuto principale
Fixed Gear Bike Chainring Replacement
Cosa ti serve
  1. Fixed Gear Bike Chainring Replacement, Chainring: passo 1, immagine 1 di 2 Fixed Gear Bike Chainring Replacement, Chainring: passo 1, immagine 2 di 2
    • Slightly loosen the two rear nuts with a 15 mm wrench to give the chain slack.
    • Remove the chain from the worn out chain ring.
  2. Fixed Gear Bike Chainring Replacement: passo 2, immagine 1 di 2 Fixed Gear Bike Chainring Replacement: passo 2, immagine 2 di 2
    • Undo all five bolts attached to the crank arm with a hex tool.
  3. Fixed Gear Bike Chainring Replacement: passo 3, immagine 1 di 2 Fixed Gear Bike Chainring Replacement: passo 3, immagine 2 di 2
    • Take the chain ring off through the crank arm of the pedal and swap the chainring of your choice.
    • Keep all five bolts in the same area to prevent losing them.
    • When bolts appear to be rusty, I recommend replacing them with a new set of bolts for the longevity of the drivetrain.
  4. Fixed Gear Bike Chainring Replacement: passo 4, immagine 1 di 1
    • Line up the chainring’s hole to the crankset and tighten all five bolts to hold the chainring in place.
  5. Fixed Gear Bike Chainring Replacement: passo 5, immagine 1 di 1
    • Lastly, attach the chain back to the new chainring.
    • Before tightening the two rear nuts back together, ensure the wheel is centered and not touching the rear bike frame.
Linea Traguardo
aljndro__
Membro da: 08/22/23
121 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 30
Tutti i Tempi: 572
