Salta al contenuto principale
Fix: makecab.exe runs for 5-10 minutes after every startup
  1. Fix: makecab.exe runs for 5-10 minutes after every startup, Find CBS log files folder: passo 1, immagine 1 di 1
    • Find CBS log files folder. The folder usually contains a .log file under 2 GB, and some .cab files.
  2. Fix: makecab.exe runs for 5-10 minutes after every startup, Remove any .log files larger than 2 GB: passo 2, immagine 1 di 2 Fix: makecab.exe runs for 5-10 minutes after every startup, Remove any .log files larger than 2 GB: passo 2, immagine 2 di 2
    • Delete, or move away if you want to keep the logs, any .log files larger than 2 GB in the CBS folder.
    • If makecab.exe is currently running and processing the log files, you may need to end it through Task manager.
Linea Traguardo
Altre 4 persone hanno completato questa guida.
Somnic
Membro da: 07/13/18
195 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 20
Tutti i Tempi: 905
