Salta al contenuto principale
Fix for Vanmoof S2 Not Charging
Cosa ti serve
  1. Fix for Vanmoof S2 Not Charging, Bike not charging when plugged in: passo 1, immagine 1 di 1
    • Under normal conditions, when plugged in and not fully charged, the light on the charger should turn red.
    • If it stays green (as shown) even while the bike itself indicates charging, the solution below will probably work for you.
    • Vanmoof has a great video on how to remove the smart cartridge. You will need to buy the necessary Torx wrench because I don't think it comes with the bike.
  2. Fix for Vanmoof S2 Not Charging, Open up the smart cartridge: passo 3, immagine 1 di 1
    • Remove all the screws from the circled plate
    • Pull apart that half of the smart cartridge. There is adhesive near the charging port so it may be a bit tough to pull apart at that end.
  3. Fix for Vanmoof S2 Not Charging, Confirm the connector has arced: passo 4, immagine 1 di 1
    • The pictured connector should look burnt in some way. It's possible that some end up completely melted.
    • Cut the plastic off the wires and then strip them so that they can be soldered to the pins
  4. Fix for Vanmoof S2 Not Charging, Solder the wires: passo 5, immagine 1 di 1
    • Solder the wires to the pins where the connector used to go
    • Reassemble everything and the bike should now charge.
Linea Traguardo
Altre 18 persone hanno completato questa guida.
Coleman Oei
Membro da: 07/08/22
823 Reputazione
2 Guide realizzate
31 Commenti
Thank you. I'm not very skilled with such things, but it worked out pretty good and I didn't find it to complicated.
Marcel M - Replica
sure np I didn't think it was "difficult" either but the description of difficult said something like "requires soldering" so I put it as difficult 🤷‍♂️
Coleman Oei -
Fiddly but not complex. I was using a soldering iron for the first time and just about managed it. Thanks for the post.
Three Sea Shells - Replica
Hi, I have same problem, I think there is a problem with the bms ! Any idea how can I fix it ?
Kreont i - Replica
sorry. dont know much besides what I wrote above. If you have more details I might be able to help. There is also a vanmoof subreddit that has been able to instruct me on how to fix a lot of the issues ive had with the bike so you might try that.
Coleman Oei -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 27
Ultimi 7 Giorni: 134
Ultimi 30 Giorni: 488
Tutti i Tempi: 17,325
