Salta al contenuto principale
Fix a Loose Mounting Dream MD2462 TV Wall Mount
Cosa ti serve
  1. Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 1, immagine 1 di 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 1, immagine 2 di 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 1, immagine 3 di 3
    • Remove the two M4x5mm bolts on the back of the TV plate using a Phillips #00 screwdriver.
    • Unplug the TV cables before removing the TV from the wall.
  2. Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 2, immagine 1 di 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 2, immagine 2 di 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 2, immagine 3 di 3
    • Remove the three lag bolts from the wall mount by using a 13mm open-end wrench.
    • If it is too loose, it can just be pulled out.
  3. Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 3, immagine 1 di 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 3, immagine 2 di 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 3, immagine 3 di 3
    • Fill the holes where the screws were secured using drywall spackle.
  4. Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 4, immagine 1 di 1
    • Locate the wooden studs on the wall using a stud finder or knock on the wall to see if the stud is behind the wall.
  5. Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 5, immagine 1 di 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 5, immagine 2 di 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 5, immagine 3 di 3
    • Use a pencil to mark three holes on the wall.
    • Use a 3/8-inch drill bit to drill three holes at the marked positions.
    • Secure the wall mount into the wooden studs using new screws or bolts.
    • Ensure that all the screws are firmly secured to the wooden stud.
  6. Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 6, immagine 1 di 2 Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 6, immagine 2 di 2
    • Test the firmness of the TV wall mount by gently pushing it up and down.
  7. Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 7, immagine 1 di 2 Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 7, immagine 2 di 2
    • Gently replace the TV back on the wall mount.
  8. Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 8, immagine 1 di 1
    • Make sure the TV is secure and well-centered on the wall mount using a spirit level gauge to confirm the inclination.
Conclusione
Emmanuel Emedeke
Membro da: 09/17/20
184 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 63
Tutti i Tempi: 4,991
