• First, determine if the problem is occurring due to water damage. To do that, look at the battery and see if the water indicator (red or blue) has been activated. If so, go to the next step.
Aggiungi Commento
  • Then, remove the battery from the phone.
Aggiungi Commento
  • Using a blow dryer, blow warm air on both the battery and the remainder of the device for about three minutes.
Aggiungi Commento
  • Bring two zip lock bags and fill them with 2 cups of either salt or rice.
Aggiungi Commento
  • Put the battery in one of the two bags and put the rest of the device in the other one.
Aggiungi Commento
  • Close the bags well so that they are airtight. Then place the bags in a dark dry spot for about a week. Make sure to be patient because the process of evaporating moisture takes a very long time.
Aggiungi Commento
  • Wait one week. Retrieve the bags. Open the bags and reconnect the battery with the body of the Motorola Adventure V750. Though the moisture indicator may still say the battery is wet, connect the battery back to the device and continue to turn on the phone.
Aggiungi Commento
  • If problem still exists, consider purchasing new battery and installing it with the old device.
Aggiungi Commento
Conclusione
Kyle
Membro da: 01/10/2012
572 Reputazione
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 304
