Salta al contenuto principale
Fix 1kHz noise on a USB microphone
Cosa ti serve
  1. Fix 1kHz noise on a USB microphone, Replace power smoothing capacitor for a larger one: passo 1, immagine 1 di 2 Fix 1kHz noise on a USB microphone, Replace power smoothing capacitor for a larger one: passo 1, immagine 2 di 2
    • Disassemble the microphone as in the video by a fellow hardware hacker https://www.youtube.com/watch?v=DDfCjkH2...
    • The key is; heat the glue - the glue is very tough and rubbery and strong - unlike regular melt stick glue. Be careful to not heat too much the mount in the middle that holds the microphone capsule. Pry-off the top, heat the glue, squeeze in the side grille into a spiral so it can be pulled out the top.
    • Remove screws of the separation plate and pull the board out. Its held in again with the same glue in the rails.
    • Note the capacitor is much smaller than the pads were designed for. For reasons I assume is - cost saving - the factory decided not to use three size of capacitor but just two.
    • Remove the capacitor and replace it with just a bigger one, perhaps from a donor board. Don't worry about the value - it just needs to smooth out the power supply rail for the FET. Ripples in the current are introduced as the devices sends USB packets every 1ms (at 1 kHz). This capacitor smooths those ripples out noticeably.
    • Do not test the microphone outside of its housing as all you'll hear is your typical 50Hz noise from the electrical system.
Conclusione
martin-kokos
Membro da: 08/26/24
100 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 226
