Introduzione
This is a guide that show you a good method to separate Samsung S9’s OLED screenand restore it with RMB-2 OCA Laminating Machine and Frozen Machine successfully.
Are you ready? Let’s roll.
Cosa ti serve
Panoramica Video
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Initially, we have to use an 8 inches of Manual Vacuum Separator to heat the screen so that the residual glue on the screen can be soften.
After that, we use a clean cloth to wipe the OLED with a little glue cleanser, so it can remove the residual glue easily and efficiently.
Then we should be patient and careful to use a yellow glue remover tool to remove the residual glue. Once removed, we should clean up the OLED with white oil.
The following part is using 17 inches of Frozen Machine to disassemble the mid-frame from the OLED. Firstly, we would place the whole screen into the working area of the frozen machine for freezing. Here it needs to take 5 minutes to freeze the screen.
Then we can use a poker card to separate the mid-frame under the low temperature after the freezing time is up.
Once separated the mid-frame, we have to use Test Boarder to test the display and the touch are on work or not.
Then we would laminate a new piece of OCA to the new glass of Samsung S9 once we confirmed the test result is no problem.
In the OCA lamination part, the tools we would use are the whole set high precision positioning edge mold of model S9 and RMB-2 OCA Lamination Machine. It would take 90s in this process.
Here we can see there’s no any bubble and folds on the new glass after the lamination through the third picture.
The next part is laminating the OLED. As same as above OCA lamination, we still use Samsung S9's positioing edge molds and RMB-2 OCA Lamination Machine. And it just need to take 90s in this LCD lamination process.
The last step is putting the screen into bubble remover to remove bubbles. It should take 5 mins to remove bubbles so that we can get a perfect effect.
We can see the final screen lamination and bubble removing effects are extremely good.
That’s all steps for Samsung S9’s broken screen replacement. Reviewing the whole process, I think that mid-frame cold separating is a key point for the entire replace process. But I think you can do it well.
