Introduzione
Is your touchscreen not working? The touchscreen sensor may need to be replaced. Read this guide to learn how to replace the touchscreen sensor, but keep in mind that you will need to cut the wristband in order to complete this repair and the band cannot be reattached.
Cosa ti serve
Unscrew all four black 3 mm screws on the underside of the watch using a T5 screwdriver.
To reassemble your device, follow these instructions in reverse order. Keep in mind that the wristband will need to be cut for this repair and it cannot be reattached.
Altre 7 persone hanno completato questa guida.
5Commenti sulla guida
Is there a company that will perform this fix for me?
Where can I get a replacement sensor?
Isn’t any step missing in that instruction ?
Removing sensor will solve the issue ? How about adding new one ?
Hi, I didnt get the point, what should I do after removing sensor? Should I clean it or something? If I need to place a new one, maybe someone knows where to get one?
viktoras -
Is anyway I can buy the bus
