Salta al contenuto principale
Fitbit Inspire 2 Wrist Straps Replacement
Cosa ti serve
  1. Fitbit Inspire 2 Wrist Straps Replacement, Wrist Straps: passo 1, immagine 1 di 3 Fitbit Inspire 2 Wrist Straps Replacement, Wrist Straps: passo 1, immagine 2 di 3 Fitbit Inspire 2 Wrist Straps Replacement, Wrist Straps: passo 1, immagine 3 di 3
    • Use a spudger or your fingernail to push back the release lever on one of the two straps on the underside of the Fitbit.
    • You may experience some resistance from the release, but don't use excessive force, as it may damage the release levers.
    Chiedi a FixBot
    Aggiungi Commento
  2. Fitbit Inspire 2 Wrist Straps Replacement: passo 2, immagine 1 di 3 Fitbit Inspire 2 Wrist Straps Replacement: passo 2, immagine 2 di 3 Fitbit Inspire 2 Wrist Straps Replacement: passo 2, immagine 3 di 3
    • As you pull back the release lever, shift the strap diagonally.
    • Remove from the Fitbit strap.
    • Repeat the process for the other strap.
    Chiedi a FixBot
    Aggiungi Commento
  3. Fitbit Inspire 2 Wrist Straps Replacement: passo 3, immagine 1 di 2 Fitbit Inspire 2 Wrist Straps Replacement: passo 3, immagine 2 di 2
    • Now that the old straps are detached from the Fitbit, take the opportunity to clean the watch and strap connection points.
    • Use a spudger to clean the inside of the strap chamber. Scrape out any residue or grime that may have built up over the past months or years.
    Chiedi a FixBot
    Aggiungi Commento
  4. Fitbit Inspire 2 Wrist Straps Replacement: passo 4, immagine 1 di 1
    • Slide the replacement straps into the given slot and the lever will click back into place.
    Chiedi a FixBot
    Aggiungi Commento
  5. Fitbit Inspire 2 Wrist Straps Replacement: passo 5, immagine 1 di 2 Fitbit Inspire 2 Wrist Straps Replacement: passo 5, immagine 2 di 2
    • The straps should be secure and you can wear your watch again!
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
MarcSerpa
Membro da: 01/09/24
163 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 10
Ultimi 30 giorni: 60
Tutti i Tempi: 955
