Salta al contenuto principale
Fitbit Charge HR Vibration Motor Replacement
Cosa ti serve
  1. Fitbit Charge HR Vibration Motor Replacement, Vibration Motor: passo 1, immagine 1 di 1
    • Remove the four 2.9 mm screws from the back of the display using a Torx screwdriver.
    • Remove the back cover from the device.
  2. Fitbit Charge HR Vibration Motor Replacement: passo 2, immagine 1 di 3 Fitbit Charge HR Vibration Motor Replacement: passo 2, immagine 2 di 3 Fitbit Charge HR Vibration Motor Replacement: passo 2, immagine 3 di 3
    • Remove the two 2.9 mm Torx screws holding the circuit board in place.
    • Carefully pry the board out using an opening tool.
  3. Fitbit Charge HR Vibration Motor Replacement: passo 3, immagine 1 di 1
    • Remove the motherboard assembly from the device by gently lifting.
  4. Fitbit Charge HR Vibration Motor Replacement: passo 4, immagine 1 di 2 Fitbit Charge HR Vibration Motor Replacement: passo 4, immagine 2 di 2
    • Locate the vibration motor on the motherboard.
    • Desolder the red and black wires connected to the motherboard from the vibration motor.
    • Red wire is located closer to the outside. Black wire is closer to the inside of the motherboard.
    • Replace with new vibration motor.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 15
Tutti i Tempi: 405
