Salta al contenuto principale
Fitbit Charge HR Screen Replacement
Cosa ti serve
  1. Fitbit Charge HR Screen Replacement, Screen: passo 1, immagine 1 di 1
    • Remove the four 2.9 mm screws from the back of the display using a Torx screwdriver.
    • Remove the back cover from the device.
  2. Fitbit Charge HR Screen Replacement: passo 2, immagine 1 di 3 Fitbit Charge HR Screen Replacement: passo 2, immagine 2 di 3 Fitbit Charge HR Screen Replacement: passo 2, immagine 3 di 3
    • Remove the two 2.9 mm Torx screws holding the circuit board in place.
    • Carefully pry the board out using an opening tool.
  3. Fitbit Charge HR Screen Replacement: passo 3, immagine 1 di 2 Fitbit Charge HR Screen Replacement: passo 3, immagine 2 di 2
    • Remove the motherboard assembly from the device.
    • Flip the motherboard over so the screen is facing upwards.
  4. Fitbit Charge HR Screen Replacement: passo 4, immagine 1 di 3 Fitbit Charge HR Screen Replacement: passo 4, immagine 2 di 3 Fitbit Charge HR Screen Replacement: passo 4, immagine 3 di 3
    • Wedge a nylon spudger between the screen and the motherboard.
    • Gently pry the screen up and remove it from the motherboard.
    • Metal spudgers can puncture an unprotected battery and damage components like the motherboard. Always choose a tool that's ESD-safe, such as a nylon spudger or plastic opening tool.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 22
Tutti i Tempi: 753
