Introduzione
This is a guide to replace the battery in the Fitbit Alta HR fitness tracker.
Cosa ti serve
Use a spudger to disconnect the cable that connects the heart rate monitor to the motherboard.
Use a hex 0.7 screwdriver to remove the screws from the motherboard.
Use a spudger to lift the battery.
When the battery is lifted, the connected components (display, motherboard, battery) will come out.
Use a soldering iron to desolder the two battery contacts from the motherboard.
Ensure positive and negative wires are in the correct positions. There are + and – signs on the motherboard. Red is positive. Black is negative.
Use a soldering iron and lead-free solder to solder the new battery to the motherboard.
Altre 3 persone hanno completato questa guida.
