Salta al contenuto principale
Fishing Line Replacement
  1. Fishing Line Replacement, Fishing Line: passo 1, immagine 1 di 1
    • Thread fishing line through all eyelets on the fishing pole.
  2. Fishing Line Replacement: passo 2, immagine 1 di 1
    • At the top of the allotted seven to ten feet, thread the line through one hook of the bobber by depressing the opposite side of the bobber so that the hook is exposed.
  3. Fishing Line Replacement: passo 3, immagine 1 di 1
    • Repeat step two for the opposite end of the bobber, threading the line through the second hook.
  4. Fishing Line Replacement: passo 4, immagine 1 di 1
    • About one to two feet before the end of the line, thread a weight onto the line.
  5. Fishing Line Replacement: passo 5, immagine 1 di 1
    • Tie a knot around the weight's eyelet. (No specific knot needed, it just needs to stay in place.)
  6. Fishing Line Replacement: passo 6, immagine 1 di 1
    • At the very end of the line, thread the line through the eyelet of the lure about 6 inches.
  7. Fishing Line Replacement: passo 7, immagine 1 di 1
    • Twist the line around itself approximately five to six times.
  8. Fishing Line Replacement: passo 8, immagine 1 di 1
    • Thread the remaining line through the hole created by the previous step near the lure eyelet.
  9. Fishing Line Replacement: passo 9, immagine 1 di 1
    • Pull the knot tight.
Conclusione
After step 9 you are ready to fish.
Trevone Martin
Membro da: 02/22/18
169 Reputazione
1 Guida realizzata
1Commento della guida
This is Joe from Durban Deep Sea Fishing Charters. This is a short and concise but very helpful guide to replace a fishing line. I will be sure to share this with my clients. Thanks guys
Joe Osborne - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 28
Tutti i Tempi: 2,079
