Salta al contenuto principale
First Act MA2039 Battery Replacement
Cosa ti serve
  1. First Act MA2039 Battery Replacement, Battery: passo 1, immagine 1 di 3 First Act MA2039 Battery Replacement, Battery: passo 1, immagine 2 di 3 First Act MA2039 Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Press the bottom tab and lift the lid that is marked "9V Battery"
    • Open the lids of both battery cartridges, use a Spudger to lift the 9-volt battery out.
    • Disconnect the attached 9-volt battery from the positive and negative terminal connections to prepare for replacement.
  2. First Act MA2039 Battery Replacement: passo 2, immagine 1 di 3 First Act MA2039 Battery Replacement: passo 2, immagine 2 di 3 First Act MA2039 Battery Replacement: passo 2, immagine 3 di 3
    • Insert a new, fully-charged 9-volt battery to the terminal connections.
    • Link the positive terminal (+) of the 9-volt battery to the positive connection.
    • Link the negative terminal (-) of the 9-volt battery to the negative connection.
    • Repeat the process for the 2nd 9-volt battery in the neighboring cartridge.
  3. First Act MA2039 Battery Replacement: passo 3, immagine 1 di 2 First Act MA2039 Battery Replacement: passo 3, immagine 2 di 2
    • Insert the 9-volt battery into the cartridge.
    • Press firmly to slide the battery into the cartridge, and close the tab to ensure the battery is secured.
    • Close the tab after the battery is secured, until the tab "clicks" into place.
  4. First Act MA2039 Battery Replacement: passo 4, immagine 1 di 2 First Act MA2039 Battery Replacement: passo 4, immagine 2 di 2
    • Make sure connections are secure and insert 9-volt batteries into the battery cartridges.
    • Close the tabs until you hear a click.
    • Now, try turning on the power switch. Get ready to rock & roll!
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 19
Tutti i Tempi: 871
