Introduzione
This FastFix is provided so that you may be able to replace a broken FirsTime Wall Clock due to a faulty movement mechanism. This is helpful so you won’t have to spend money on replacing this item. It is a short and easy fix!
Cosa ti serve
Using a Phillips #1 screwdriver, remove all four screws on the back of the clock.
Altre 17 persone hanno completato questa guida.
5 Commenti
Is there a you tube showing these steps?
Thank you! there was one tricky thing—the parts I got in the order did not match what I took off, so I had to reconfigure it a bit per new instructions that came with the parts. But I figured it out! Thank you for this instruction.
Excellent illustrations!!!
there seem to be 2 projections keeping the back & glass together.
I don't want to break them.
