Salta al contenuto principale
Firmware update or recovery - PC (All models)
Cosa ti serve
  1. Firmware update or recovery - PC (All models), Plug the controller in: passo 1, immagine 1 di 1
    • Connect the controller using a USB-C OR MicroUSB cable. Plug the controller into a USB port on your PC.
    • Bluetooth firmware updates are not supported.
  2. Firmware update or recovery - PC (All models), Download the Xbox Accessories app.: passo 2, immagine 1 di 2 Firmware update or recovery - PC (All models), Download the Xbox Accessories app.: passo 2, immagine 2 di 2
    • Download the Xbox Accessories app from Microsoft Store using this link.
    • After it has finished downloading, you can launch it either straight off the app's page or from your Start Menu.
  3. Firmware update or recovery - PC (All models), Prepare the app for the firmware update: passo 3, immagine 1 di 2 Firmware update or recovery - PC (All models), Prepare the app for the firmware update: passo 3, immagine 2 di 2
    • After you launch the app and it finishes loading, the controller should show up like on the first photo.
    • Click on the three dots under the Configure button.
    • If the button over the Buzz/Vibrate this controller says No update available, your controller is already up to date and the guide ends here.
  4. Firmware update or recovery - PC (All models), Update the firmware: passo 4, immagine 1 di 2 Firmware update or recovery - PC (All models), Update the firmware: passo 4, immagine 2 di 2
    • Press the Continue button and wait for the process to finish.
    • In most cases, the firmware can be recovered, but be careful not to disconnect the controller during the update. Any loss of connection, be it disconnecting or PC power loss may damage the controller beyond repair.
    • After the update, press Close. Your controller is now up to date and should be fully usable with your PC, Xbox One or Series S/X consoles.
Linea Traguardo
Altre 6 persone hanno completato questa guida.
SojerManLan
Membro da: 07/07/21
253 Reputazione
1 Guida realizzata
1Commento della guida
Use this video if you need to undo anything.
Revert Firmware
go away - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 36
Ultimi 30 Giorni: 147
Tutti i Tempi: 6,083
